Keels
For future reference, this thread explains the difference between the different types of lower front suspension mounts.
Single Keel
The lower wishbones are connected to a 'keel' which protrudes out of the bottom of the nose section of the chassis. Lower wishbones can be made as a single piece.
This is the old standard layout for the second half of the 1990's. Allowed the lower areas of the chassis to be raised for improved airflow under the car.
Twin Keel
The lower wishbones are mounted to separate keels which protrude from the lower corners of the chassis.
Developed to further improve airflow under the nose of the car.
Small side keels are prone to flexing.
V-Keel
Lower wishbones mount to an upside-down ‘A’ frame instead of a single keel.
Designed to allow airflow through the keel itself. Should be nearly as stiff as a single keel and with a partial improvement in air flow.
‘Zero’ Keel
Lower wishbones mount to the bottom corners of the chassis. In effect using stunted twin keels.
Both upper and lower wishbones are angled upwards to the chassis to allow this layout.
Has same aerodynamic benefits as twin keel, but is significantly stiffer.
Does lead to a compromised suspension geometry and reduced roll-stiffness.
‘Interchangeable’ Keel
no shown on diagram
Invented by a member of thescuderia.net (Tobes) in early 2006 to explain all the rumours about the keels that years Ferrari was supposed to have, this is basically a hybrid of all other types of keel that would in theory allow you to change from one to another by un-bolting various parts of the chassis, in the area behind the nosebox.
Unfortunately (for Tobes, as it meant he was talking rubbish) it was not used on the '06 Ferrari and is unlikely to ever be used due to the inherent structural weaknesses of not having your suspension mounts bonded into the chassis.
27 -4 WC's
24
Was wondering how long it would take before someone noticed that!
