Results 1 to 14 of 14
Thread: So we've all heard that the team...
    Northglenn
    has a problem getting heat into the tires on the first lap and yet Hami boy and his group of pirates haven't had this problem.
    We also know from last year the Mc's were running Nitrogen in their tires while Ferrari were using C02.
    So for long runs, C02 seems to be better, keeps the tire cooler, keeps them from graining so bad and keeps Ferrari in the winners circle but is hard to qualify on.
    So here is my question.
    Why not use a combination of both? Nitrous Oxide?
    That way you get the properties of Nitrogen, quicker heating intially, but the O2 would keep the overall temperature down for the long haul..
    I am a math guy, not a chemist so someone here might know better...
    N02 is used for engine boost but is only combustable when mixed with fuel and under pressure... It's also known as laughing gas and available at many a dentist office...
    Any thoughts?
    President, Scuderia Ferrari Club of Denver - The Official Passion
    http://www.scuderiaferrari.club
    denver@scuderiaferrari.club
    Sweden, Borås
    Why not have NO2 in the tires in the qualifying and CO2 in the race??? Maybe that's againt the rules but I don't know.
    some general info i found from speedtv
    http://formula-one.speedtv.com/artic...s_of_the_f2007
    and this
    Another interesting point is that most of the F1 teams use dry nitrogen gas to inflate their tyres instead of air. This is done for two reasons. Firstly the moisture content of air is variable depending on the local weather conditions and this differs considerably between some of the exotic locations on the GP calendar. By using dry nitrogen gas the tyres will behave in a predictable way wherever they are being used. The second reason is that air is a mixture of nitrogen (78%) and oxygen (21%). Oxygen gas is far more reactive than nitrogen and at the high operating temperatures of F1 tyres (> 100°C) the oxygen reacts with the tyre, reducing the total pressure inside. Using pure nitrogen removes this problem and tyre pressures remain far more consistent.
    I'm sure I read somewhere that Ferrari's tyre gas is a mixture of gases, not purely just CO2. If I find the article again I'll post it up.
    May 2003
    The Midlands
    I thought the gas mixture in the tyres was supposed to be one of the bits of info McLaren got from Stepney?......
    and thinking about it, since when did CO2 + N2 = NO2..... or has my chemistry knowledge completely escaped me?
    Surely a combination of the two gasses would just mean you had a mixture of CO2 and N2 in whatever proportion you chose, rather than the two becoming chemically linked.
    Anyhoo, I think changing the gas is a small thing compared to general car setup.
    The McLaren and Ferrari have different levels of mechanical and aero grip, as a result one is harder on it's tyres and so can heat them up quicker, but then will wear them out faster - hence McLaren often choosing the harder compound as their best tyre for the race, while Ferrari run more stints on the softer compound.
    McLaren have even run quali on harder tyres in some cases, which suggest that they can generate enough heat in a single warm-up lap to make them useable for a flyer.
    Disclaimer: The views expressed by this forum member are purely opinions and observations and should not be interpreted as fact, or indeed as anything other than a cheap gag for my own amusement.
    Jun 2006
    Just a thought - NO2 is a highly oxidising flammable gas that is known to cause ignition when exposed to certain plastics, elastomers and rubbers. It is also corrosive in the presence of water. Generally speaking, tyre inflation gases should be inert in the event of an accident or mishap. Nitrogen Dioxide might not be the best choice...
    A bad day driving is better than a good day working.
    Quote Originally Posted by kaiser
    Exactly what I was going to point out, you really don't want a strong oxidiser like NO2 near very hot things and things full of petrol!
    Btw incase anyone was wondering Nitrous wouldn't give you the properties of Nitrogen and Carbon Dioxide combined, chemistry isn't that simple. Think about the result of reacting sodium metal with chlorine gas, the product isn't something with a combination of properties.
    "We win together, we lose together"
    Quote Originally Posted by Shahid
    Yeah was thinking that myself
    Why couldn't you qualify on 1 gas, and race on the other?
    would make sense to qualify on 1 and use the mixture which give better long run performance for the race.
    Jul 2008
    Perth WA
    Nitrous Oxide is N2O.
    It's not flammable. It decomposes at high temperature (eg when injected into engines) to release additional Oxygen. The extra Oxygen can be used to burn additional fuel, boosting power.
    As it is a gas at room temperature, when used in vehicles it can be stored as a liquid under extreme pressure to save space.
    Releasing liquid N2O into an engine causes the N2O to evaporate, causing a massive temperature drop, resulting in a denser inlet charge - you can squeeze more fuel and air into the cylinder to get more power.
    I don't think it's a good gas for tyres though.
    Ferrari really need Bridgestone to make softer tyres!
    Monet ratsastajat menettivät hampaat onnettomuuden aikana, ja he hoitavat sitä klinikoilla https://hammastieto.fi/
    Mar 2017
    hellas
    Quote Originally Posted by rehohor View Post
    What kind of language is this
