Page 2 of 3 FirstFirst 123 LastLast
Results 31 to 60 of 88
Thread: Ferrari 599 FXX pics
    Greece-Sweden
    Quote Originally Posted by Dino Scuderia View Post
    Who knows...???
    For now I have been slowly making a 599 GTC.
    cant wait to see your creations m8 u always do a great job!!!
    Greece-Sweden
    While based on the 599 GTB Fiorano ,with the same transaxle layout and engine type, this prototype is an extreme track car. Ferrari's engineers have carried out extensive work on the engine's combustion chambers and inlet and exhaust tracts. These modifications, combined with the fact that internal attrition has been reduced and the maximum revs have been boosted to 9,000 rpm, helped achieve the target power output of 700 hp at 9,000 rpm. Particular attention was also paid to cutting the weight of the engine unit components. This was achieved both by optimising forms – as in the new crankshaft – and adopting exclusive materials, as in the carbon-fibre used for the intake plenums. A new gearbox shift strategy cuts overall gear-change times to 60 ms.
    The 599XX is characterised by an innovative electronic concept called the 'High Performance Dynamic Concept', which has been designed to get maximum performance from the car by managing the combination of the car's mechanical limits with the potential of its electronic controls. The mechanical and electronic systems work together to get the maximum performance from the car under extreme high performance driving, for consistent lap times. The sporty handling has been improved thanks to the adoption of second generation SCM suspension system. Track usage is also made easier thanks to the new 'virtual car engineer', a screen in the car that provides a real-time indication of the vehicle's efficiency.
    The 599XX's aerodynamics were honed in numerous Wind Tunnel test sessions with the result that the car now boasts 280 kg of down-force at 200 km/h (630 kg at 300 km/h). The front underside of the body is completely faired-in and the vents that channel hot air from the engine bay have been moved to the bonnet.
    The 'Actiflow™' system increases down-force and/or cuts drag, depending on the car's trim cornering conditions, courtesy of the use of a porous material in the diffuser and two fans in the boot, which channel the air flow from under the car out through two grilles next to the tail lights. Winglets have been added to the rear buttresses to increase downf-orce, while synthetic jets have also been incorporated into the rear of the car to control and smooth the air flow and to reduce drag. Ferrari's engineers have also used F1-derived 'doughnuts', which partly cover the brake discs and wheel rim. These have the dual functions of improving aerodynamics and cooling the brakes.
    In terms of the bodywork, composites and carbon-fibre have been widely used and the engineers drew on their experience in working with aluminium to reach the weight target. The development of increasingly high-performance materials has also benefited the carbon-ceramic braking system. The brake pads are now made from carbon-fibre, which means the callipers are smaller while guaranteeing the same efficiency. The new racing carbon-ceramic braking system also delivers shorter braking distances and is generally more efficient due to the weight saving.
    The 599XX comes with slick tyres (29/67 R19 front and 31/71 R19 rear), specifically developed to maximise stability in cornering and increase lateral acceleration. They are fitted to 19 x 11J wheel rims at the front and 19 x 12J at the rear.
    Some info from the ferrari community site
    http://www.ferrari.com/English/GT_Sp...X_Ginevra.aspx
    Asgard
    Getting on Track: Ferrari releases more pics, details on experimental 599XX
    by Noah Joseph on Apr 27th 2009 at 12:32PM
    Road cars have laws to contend with, and racing cars have regulations to uphold. But for track cars, the sky is the limit. Unfortunately for track enthusiasts, purpose-built track cars built from the ground up with a blank sheet of paper and a limitless sky are few and far between. One example comes from Ferrari with its XX-rated development program that creates a series of cars that bridge the gap between road and track. First up was the FXX, an Enzo with some extra kit. That was followed by the even more extreme FXX Evoluzione. But at the Geneva show last month, Ferrari took the wraps off the 599XX, a rolling laboratory based on the 599 GTB Fiorano only unbound by the rules of governing bodies. And while the 599XX's debut was accompanied by only limited details and even fewer photos, Maranello's finally released more of each to salivate over.
    Over the course of its ongoing development – that is, after all, the point of the XX programs – the 599XX will receive all manner of new features and technologies. There's even word it may serve as a test bed for the adaptation of Formula One's KERS regenerative braking system for future road cars. But in the meantime, Ferrari's engineers have started with a host of aerodynamic and engine modifications. Added aerodynamic elements abound, some more visible than others. Little black winglets protrude from the C-pillars (which themselves were already aerodynamically optimized on the road car), and the wheels integrate F1-style "donuts" to channel the air for optimized cooling and clean airflow. Underneath the bodywork, a new Actiflow system employs a porous diffuser and two fans in the trunk to channel the airflow for increased downforce at cornering speeds or reduced drag at higher speeds. All that and more adds up to 617 pounds of downforce at 124 mph or 1,389 pounds at 186 mph. Reduced mass inertia in the engine compartment helps the V12 produce 700 horsepower at the XX's stratospheric 9,000 RPM redline, the shift program has reduced gear changes to just 60 milliseconds, and the carbon ceramic brake pads are gripped by experimental carbon-fiber calipers to keep it all under control. All that new tech helps the 599XX lap Ferrari's own Fiorano test track in 1 minute, 17 seconds... faster than any road car the company has ever produced, a tick under the FXX's lap time, and faster than some of the company's modern race machinery. Follow the jump to read more details in the press release, and check out the studio shots in the high-resolution image gallery below.
    PRESS RELEASE
    599XX
    While based on the 599 GTB Fiorano with the same transaxle layout and engine type, this prototype is an extreme track car. Ferrari's engineers have carried out extensive work on the engine's combustion chambers and inlet and exhaust tracts. These modifications, combined with the fact that internal attrition has been reduced and the maximum revs have been boosted to 9,000 rpm, helped achieve the target power output of 700 hp at 9,000 rpm. Particular attention was also paid to cutting the weight of the engine unit components. This was achieved both by optimising forms - as in the new crankshaft - and adopting exclusive materials, as in the carbon-fibre used for the intake plenums. A new gearbox shift strategy cuts overall gearchange times to 60 ms.
    The 599XX is characterised by an innovative electronic concept called the "High Performance Dynamic Concept" which has been designed to get the maximum performance from the car by managing the combination of the car's mechanical limits with the potential of its electronic controls. The mechanical and electronic systems work together to get the maximum performance from the car under extreme high performance driving, for consistent lap times. The sporty handling has been improved thanks to the adoption of second generation SCM suspension system. Track usage is also made easier thanks to the new "virtual car engineer", a screen in the car that provides a real-time indication of the vehicle's efficiency.
    The 599XX's aerodynamics were honed in numerous wind tunnel test sessions with the result that the car now boasts 280 kg of downforce at 200 km/h (630 kg at 300 km/h). The front underside of the body is completely faired-in and the vents that channel hot air from the engine bay have been moved to the bonnet.
    The "ActiflowT" system increases downforce and/or cuts drag depending on the car's trim cornering conditions, courtesy of the use of a porous material in the diffuser and two fans in the boot which channel the air flow from under the car out through two grilles next to the tail-lights. Winglets have been added to the rear buttresses to increase downforce. while synthetic jets have also been incorporated into the rear of the car to control and smooth the air flow and to reduce drag.
    Ferrari's engineers have also used F1-derived "doughnuts" which partly cover the brake discs and wheel rim. These have the dual function of improving both aerodynamics and brake cooling.
    In terms of the bodywork, composites and carbon-fibre have been widely used and the engineers drew on their experience in working with aluminium to reach the weight target. The development of increasingly high-performance materials has also benefited the carbon-ceramic material braking system. The brake pads are now made from carbon-fibre which means that the calipers are smaller whilst guaranteeing the same efficiency. The new racing carbon ceramic braking system also delivers shorter braking distances and is generally more efficient due to the weight saving.
    The 599XX comes with slick tyres (29/67 R19 Front and 31/71 R19 Rear) specifically developed to maximise stability in cornering and increase lateral acceleration. They are fitted to 19 x 11J wheel rims at the front and 19 x 12J at the rear.
    source
    More pics of this beauty
    More at the source
    Forza Ferrari! ~ Sempre Ferrari!
    I really hope Clarkson gets his hands on this baby!
  5. #35
    Asgard
    POWEEEEEEEERR!!!
  6. #36
    Peterborough
    http://www.autocar.co.uk/News/NewsAr...llCars/241832/
    Hardcore Ferrari 599XX spied
    ..The hardcore track-focused version of Ferrari's 599 Fiorano, the 599XX, has been spied testing at the Fiorano test track.
    The 599XX gets a retuned version of the 599's V12 engine, with its rev limit boosted to 9000rpm and its weight reduced by the adoption of a new crankshaft and more extensive use of carbonfibre in ancillary parts.
    Although confirmed details are scarce, Ferrari says it "achieved its goal" of just under 700bhp at 9000rpm.
    The power is transmitted through a new version of Ferrari's robotised manual gearbox that features shift times of just 60ms. Ferrari claims that the 599XX can lap its Fiorano test track in 1m 17sec, less than a second off the time of the Enzo-based FXX that it will replace.
    The most obvious external alterations to the regular 599 are a variety of carbonfibre additions, including a small roof spoiler, carbonfibre brake disc covers and a enormous carbonfibre undertray and rear diffuser.
    Inside, the cabin has been stripped out to race specification, with a bare dashboard and carbonfibre cladding. It does feature a display screen, however; it's used by Ferrari's 'virtual car engineer', which provides instantaneous data on the vehicle's efficiency.
    The 599XX replaces the FXX as the customer-owned testbed for Ferrari's engineers. Buyers drawn from Ferrari's most valued customer base will only be able to drive the car at Ferrari-nominated track days in 2010 and 2011.
  7. #37
    Romania, Europe
    Lovely pics, what a beautiful car!
    Forza Ferrari!
    CHELSEA FC 2009-2010 CHAMPIONS !
    "I am so proud about the people around who support me more than ever, more than 100 percent, much more than I expected" Go Felipe !
  8. #38
    Look at that thing!!!
    Die Perd se naam is pegasus abdel kader schrikt der woestijnen van bagdad tot dakar, seun van benedictus ernius quintus magnus van nassay en irma vor schimmelpernning von appeldoorn van tahiti in die heilige eg verbind kragtens die ewige edik uitgevaardig deur keiser tertius tillius theorodus en biskop merkenzein de mont saint allegonde van die vatikan.
  9. #39
    Jun 2005
    As stunning as she is, my heart is with the FXX, especially the black no. 30.
    "...as always for the Scuderia, the good of the team comes first."
    "We are Ferrari and we will never give up until the moment when the maths says it's over."
  10. #40
    Not impressed at ALL , to me is just a red car with Ferrari badges .
  11. #41
    Quote Originally Posted by xpman View Post
    aahh what a shame...
  12. #42
    Btw can I find the FXX's specs somewhere?
  13. #43
    zakfourie mate
    in answer to your question about the FXX spec hope this will help
    Engine: Longitudinal, rear-mounted, 75 degree, naturally-aspirated aluminium V12
    Valvetrain: DOHC, 4 valves per cylinder with continuously variable timing
    Fuel system: Bosch Motronic ME7 Sequential Electronic Injection
    Horsepower Max: 800 hp (597 kW) at 8500 RPM[2]
    Specific Output: 127.75 PS (126 hp/94 kW) per litre
    Drive system: RWD w/TCS
    Construction: Carbon fiber body over carbon fibre tub with rear alloy subframe
    Front brakes: Brembo CCM (carbon-ceramic) discs w/6-piston calipers, power assist ABS
    Rear brakes: Brembo CCM (carbon-ceramic) discs w/4-piston calipers, power assist ABS
    Front wheels: 483 mm (19 in) x 229 mm (9 in)
    Rear wheels: 483 mm (19 in) x 330 mm (13 in)
    Steering: Rack and pinion with power assist
    Suspension: triple wishbones with push-rod actuated coil-shock units, adaptive dampers, electronic shock absorbers, anti-roll bar
    Wheelbase: 2400 mm (94.5 in)
    Front track: 1660 mm (65.4 in)
    Rear track: 1650 mm (65 in)
    Rear view is provided by a roof mounted video camera displayed on a small inboard screen.[2]
    Top Speed: 217 mph (349 km/h)[2]
    This is a FERRARI (below) and Not that THING .......
  14. #44
    in a house
    pure beauty and POWERRRRRR
    but what`s the deal with the Michelin tyres ????
  15. #45
    Dec 2009
    bangladesh
    awesome pics dude ....
    thanks a lot for the post ........
    i just love to see Ferrari cars ....
    the pics is just awesome dude ................
  16. #46
    Leeds,England
    Quote Originally Posted by Testarossa6000 View Post
    do you think he's had to hand it back? or do you reckon luca di has let him keep hold of it?
  17. #47
    Asgard
    Quote Originally Posted by ali355 View Post
    Unless he payed for it, he'd better hand it back
  18. #48
    Jan 2009
    both really quite ugly:xmasredface:
  19. #49
    Asgard
    [YT]7ayxMWUs6N4[/YT]
  20. #50
    stowmarket
    stowmarket
    No official Ferrari presence at Detroit. A 599XX on display to celebrate the Fiat-Chrysler partnership.
    Maranello, 8 January 2010 – Although Ferrari will not officially take part in the 2010 North American Auto Show in Detroit, the company will display a 599XX on the Chrysler stand to celebrate the historic Fiat-Chrysler deal.
    The 599XX is an extreme, high-performance berlinetta and is packed with innovative technology. The car is not homologated for the road, being aimed only at non-competitive track use, and is reserved for just 20 select clients.
    This “laboratory” model is the result of extensive research in both the road car and Formula 1 fields. It brims with new solutions in terms of aerodynamics, electronic controls and chassis dynamics, with many being proposed together for the first time ever on a car and, of these, several are unique to this model. As is usual with Ferrari’s advanced research projects, the experience gained with this car will be used as the basis for developing future road cars with extreme high-performance characteristics.
    The 599XX is also an example of Ferrari’s exclusive and limited production. All Prancing Horse cars are designed, engineered and developed entirely in-house in the company’s factory in Maranello and incorporate all the latest specialist technologies that can only be applied to low-volume production like Ferrari’s.
    The official track debut of the 599XX for the client test-drivers is at Homestead in Florida in March.
    Asgard
    Ferrari 599XX makes track debut at Valencia with Massa at the wheel
    It's been almost a year since the Ferrari 599XX made its debut at the Geneva Motor Show, and we've seen the factory-fettled racer quite a few times since. Each of those times has been either in a dealership or on a show floor, though, and the 599XX has yet to be seen running in anger. Until now.
    Just ahead of Ferrari's test of their new Formula 1 car at the Ricardo Tormo circuit outside of Valencia, the 599XX turned its first wheel on-track with none other than Felipe Massa behind the wheel. Massa led a group of seven cars around the circuit, the others piloted by the lucky members of Ferrari's Corse Clienti program. Fortunately, we might just get to see the 599XX here in the States, as Ferrari has planned various events in America, Europe and Asia for their most special customers. We've included a video of the proceedings after the jump, along with Ferrari's brief press release, and you can check out photos from the 599XX's debut in the gallery below.'
  23. #53
    Feb 2009
    HR
    So here is a few Hi. Res. Images from Valencia 31/01/2010 with Massa in 599XX car...
    >>> Megaupload Download <<<
    >>> RapidShare <<<
    cheers
  24. #54
    Greece-Sweden
    wow these are great pics !!! i like this car and 800 horse power ,,,,,,, miam miam miam
  25. #55
    Sep 2007
    Hertfordshire
    Thanks, This car is amazing,
    Racing is life and life is a risk - Michael schumacher
  26. #56
    Nov 2007
    Italy
    Wowww, grazie amici!!!
  27. #57
    Sep 2006
    Tampere, Finland
    That car is stunning!
  28. #58
    Record of the Ferrari 599XX at the Nürburgring announced in Beijing
    Beijing, 23 April - The Ferrari 599XX is the first ever production-derived sports car to break the 7-minute barrier on the classic 20.832 km Nordschleife circuit, lapping in 6 min 58.16 sec.
    The 599XX, which inspired the 599 GTO, is an extreme berlinetta designed for track but not official competition use, and is a veritable technological laboratory incorporating a number of innovative solutions. Some of these will remain the exclusive preserve of the 599XX while others have already filtered down to the 599 GTO, introduced today at the Beijing Motor Show. These include the wheel doughnuts of F1 derivation which serve two purposes - to reduce turbulence and thus drag, and improve brake cooling.
    Powered by a development of the V12 engine used by the 599 GTB Fiorano, the 599XX features Ferrari's High-Performance Dynamic Concept, a novel integrated design and chassis set-up that uses sophisticated electronics to govern the mechanical limits of the handling for maximum performance.
    On the aerodynamics front, the car sees the introduction for the first time of the Actiflow™ System that increases downforce and/or cuts drag depending on the car’s trim during cornering. This, together with other careful detailing, ensures that the 599XX boasts extraordinary levels of downforce - up to 630 kg at 300 km/h.
    Fundamental to the performance of the car was the development of specific components undertaken together with our technical partners: Brembo for the carbon-ceramic brakes, Michelin for the tyres and Shell for the fuel and lubricants.
    Taken from:
    http://www.ferrari.com/English/News/...rburgring.aspx
    FORZA FERRARI
  29. #59
    What can I say, just wow! Forza Ferrari!
    The future is RED
  30. #60
    Quote Originally Posted by RED View Post
    Taken from:
    So, the 599XX is quicker around the Nurburgring than a 1975 F1 Car (312T)
