Yes the calculates hp is the same, but that is not a function of how much work an engine can do.
Once again, it's simple math (and physics). If we want to calculate the amount of Work that can be done or the distance an object can be moved, we need to know the force, mass of the object and angle of the force when applied to the object. Other forces like friction would act opposite to the applied force. Horsepower is not a force. So, you would have to multiply the HP number by 5252 and divide by the rpm, to get the actual Force. Oh crap. That's torque. You see your problem? In order to know how much work an engine can do, you need to know its torque.
That v12 won't pull any a trailer full of goods. Regardless of what rpm u slip the clutch at. The C16 makes 2,050 ft lb or torque at 1,300rpm, which is why it's used in heavy equipment. It's low rpm is a function of air supply limitations. The torque curve calls off after 1,700r or so, there is no need to keep revving.
The engine in my car can physically rev to 8,000 or so but the torque curve falls off at 7200 because of lack of air due to the intake design the intake port on the cylinder and being naturally aspirated. So I shift at 7400, no point in revving higher because I won't make any more "power" it has nothing to do with longevity as the components will live at 8k just fine.
Once again, I'm not saying one is more important than another (Hp vs Torque) I'm just saying and engine's output is torque and the HP is a calculation. An engines a ability to move things is governed by how much torque it can produce.
When starting from a dead stop, you need torque to move you. Gears and transitions multiply torque, that's why automatic transmissions have Torque Converters and not Horsepower converters. If your engine can produce more torque at any given rpm, it will calculate to have more HP.
