Page 6 of 16 FirstFirst 12345678910111213141516 LastLast
Results 151 to 180 of 452
Thread: 2019 Spanish GP: Practices & Qualifying
  1. #151
    And to all this ,Pirelli also lowered the pressures by 1 psi !!!
    I was too early, still 1 hour to FP3.
  3. #153
    looks like it could rain today, dark clouds
  4. #154
    Quote Originally Posted by KimiBot View Post
    off topic: what's your prediction on Slovakia vs Finland tonight?
  5. #155
    Sep 2007
    Hungary
    I think it can be a good news for us.
  6. #156
    Monaco will be LeClerc's biggest win of the season!! Merc will easily be second.
    You are serious or...?
  7. #157
    Quote Originally Posted by Ferrarichamp View Post
    I just follow F1, I guess you are talking about hockey, I have to say that I don`t have a clue
  8. #158
    yeah ice hockey, no probs
  9. #159
    Quote Originally Posted by distortion View Post
    Correct... 4 wheel steer, interlinked just out of rules reach, and tires made just for them.
    Quote Originally Posted by darkchild View Post
    Might be 4 wheel steering, I have no idea my self. RB is comfortably behind like we are, so...
    Quote Originally Posted by erikejw View Post
    Mechanical as in 4 wheel steering :)
    That why their apex speed is so high, andonky in slow corners where aero is not a deciding factor.
    Is this confirmed somewhere? Or is it just a rumor?
    It was written on an Italian F1 website. Also, you can tell the car is turning on its own axis. It was evident in testing, the car does not slide into the corner, just turns on its axis.
    Also, when you look at the apex speeds, how late they brake, and how far they hold the brake, you can tell the car is turning while the brakes are applied. They can carry huge speed into the corner. The brake steer is not a huge thing to impliment, I dont know why they dont do it in Ferrari.
    It's rear wheel "steering". Mercs experimented with this at the end of 2018 (excerpts from Italian Motorsport)
    How many Mercedes experiments: the W10 simulates the rear steering wheels
    https://cdn-2.motorsport.com/images/...edes-amg-f.jpg
    The silver arrow in the first test session in Barcelona tried the basic set-up: the front was chosen for the push rod strut, while behind it worked on four steering wheels and the height from the ground. The real Mercedes will appear next week.
    The second analysis concerns the front suspension: the W10 has two configurations. The more traditional one was preferred with the external bracket of the push rod strut that is added to the pivot with which the upper triangle is not only raised, but also offset from the lower one.
    https://cdn-7.motorsport.com/images/...0-detail-1.jpg
    Mercedes engineers have worked hard to gather data on the two front suspension options, while behind they have focused on two other very important aspects: steering wheel simulation and ground clearance. . According to the rumors of the paddock there were a couple of ZF technicians to support the engineers of Brackley to find the right set-up of the "steering".
    Let's be clear from the start: it's all legal, because the engineers of James Allison would work on the gray part of the regulation, namely on all brake-by-wire tolerances, engine maps, differential management and resilience of the suspensions. The (difficult) combination of all these elements would give an important result that would facilitate the entry of the arrow in the curve of silver, allowing a greater speed in cornering. The image we posted above is rather eloquent about the behavior of the rear tires at the entrance to the chicane in Barcelona.
    If we add to all this that on the W10 were made of ground clearance tests with the car that has also traveled with the bottom parallel to the asphalt and then get to the usual value of Rake (1.2 °), it is easy to see how the silver arrow he shot in Catalunya was a sort of laboratory car.
    In these days both in Breckley and in Brixworth will be analyzed all the data collected and from Tuesday, again in Spain, we will see a W10 in a more projected capacity at the Australian GP ...
    https://translate.google.com/transla...4/&prev=search
    and the others teams? nobody else has tried it?
    nope
  10. #160
    May 2006
    hull
    Disagree with the nope.
    All the teams will have something similar to rear wheel steer, just not as advanced
  11. #161
    Quote Originally Posted by evo_spook View Post
    Like who and care to share the link or links???.................please.
  12. #162
    It’s always the tyres, I’m telling you - MercPirelli just gets the tyres working better.
    May 2006
    hull
    Come on, you don’t believe they all have something similar, rear steering that has being around for a 100 years.
  14. #164
    Jun 2017
    Formula 1 is all about advanced stuff, they keep on doing something new and unique and powerful, all others do then is try to catch up.
  15. #165
    First I've heard of this in F1 while still being legal in this hybrid formula.
  16. #166
    May 2006
    hull
    I read it from f1technical
    Contact: Contact dans79
    Re: Mercedes-AMG F1 W10 EQ Power+
    0 Report Quote
    Post by dans79 » 23 Feb 2019, 20:03
    I believe if you read the vagaries of the rules, active 4-wheel stealing is prevented passive is not. A lot of the teams have been doing a small amount of it passively for a while, the question is to what extent is Merc working towards.
  17. #167
    Mercs reverted back to their old spec mirrors.
  18. #168
    what about Max?
    "I've always believed that you should never, ever give up and you should always keep fighting even when there's only a slightest chance " : - Michael Schumacher
  19. #169
    So the new one’s are deemed illegal?? Looks like it is.
  20. #170
    Cool condition, Current track temp 28C, during FP2 yesterday it was 43C.
  21. #171
    Temps cooler today.
  22. #172
    My thoughts exactly.
  23. #173
    Croft saying Circuit de Catalunya & Hockenheim could miss out next year, replaced by Zandavoort & Vietnam
    “I prefer to beat them on Sunday” -Fernando Alonso, Press Conference Korean GP 2010
    "Giornata fantastica !!"- Andrea Stella, European GP 2012
  24. #174
    FP3 Results – 2018 Spanish Grand Prix
    Lewis Hamilton Mercedes 1:17.281
    Valtteri Bottas Mercedes +0.013
    Sebastian Vettel Ferrari +0.269
    Kimi Raikkonen Ferrari +0.300
    Daniel Ricciardo Red Bull Racing +0.700
    Kevin Magnussen Haas +1.076
    Romain Grosjean Haas +1.425
    Carlos Sainz Renault +1.502
    Fernando Alonso McLaren +1.566
    Pierre Gasly Toro Rosso +1.605
    Nico Hulkenberg Renault +1.624
    Max Verstappen Red Bull Racing +1.732
    Esteban Ocon Force India +1.840
    Stoffel Vandoorne McLaren +1.955
    Charles Leclerc Sauber +2.011
    Sergio Perez Force India +2.095
    Brendon Hartley Toro Rosso +2.147
    Marcus Ericsson Sauber +2.463
    Lance Stroll Williams +2.619
    Sergey Sirotkin Williams +2.628
  25. #175
    Quote Originally Posted by Rishu View Post
    Yep, looks like Zandvoort is on for the 2020 calender.
  26. #176
    First Malaysia, then Barcelona and now Hockenheim, that’s disaster from driver’s perspective
  27. #177
    flat spot
  28. #178
    usually good sign when Seb finding extremes in FP, we`ll see
  29. #179
    There's a YouTube video of the Hanoi track sim.
    Looks okay from the sim.
  30. #180
    and Charles just keeps his level, he did surprise me this year, he is great
