I've seen the FIA put up kerbs and sensor wires so drivers stay within track limits.....like overnight.
yep, it's a head scratcher that's for sure. Qualifying, they were strick on track limits. During the race, not so much. GIVE ME A BREAK!!!!![]()
So Bottas got the fastest lap and extra point.....right. So exceeding track limits to get the fastest lap and extra point counts then at T4???
https://twitter.com/thomasmaheronf1/...257671/photo/1
I don't know....but it was'nt 29 times.
Look, track limits should have been enforced like the way it was in qualifying....however it was'nt during the race. When a driver exceeds track limits, regardless of the situation, they gain an advantage by:
1.) tire wear
2.) time advantage
Exceeding track limits 29 times gave Lewis a 5 to 6 sec total time advantage as well as a tire preservation advantage.
Well you sure did and you also said most drivers ran wide at turn 4 and that the limits were not enforced.....
A Deep Dive Into Turn Four's Track Limits | Jolyon Palmer Analysis | 2021 Bahrain Grand Prix
https://www.youtube.com/watch?v=N1zR74ijo7U
I'm sorry but the stewards messed up. As for Michael Masi's explanation, why then did they only rein LH in once RB had made the decision to do the same?
As far as I could tell, RB did not complain to the stewards about LH, they simply told their driver to do the same. The stewards should have just stayed out of it and let Max continue to do the same since the racing notes allow it and LH had been doing it the whole time. It's the fact that the stewards jumped in and disallowed the action MID-RACE (after allowing LH to do it for half the race) that made a mess of the situation.
As for Max's overtake, that's pretty straightforward. It's not allowed. Regardless of whether drivers were permitted to leave the track when running alone, overtaking is a different and straightforward story.
Norris seems to think otherwise. He breaks down his point in the video.
Norris: Max completed Hamilton overtake on track
https://www.planetf1.com/news/max-ve...rain-overtake/
That's where the track limits non enforcement becomes a problem. Drivers are going off track every lap then doesnt that area count as part of the track? Verstappen passed Hamiltln using the same amount of track that the drivers were using all race up until FIA said not to.
I love how Karma is getting served for RedBull. Those fools laughed at us and made a mockery out of us for giving out wrong calls during moments of pressure. Now, the first thing they do when they have a car capable for competing for a WDC is literally steal a defeat from the jaws of victory.
"I've always believed that you should never, ever give up and you should always keep fighting even when there's only a slightest chance." - Michael Schumacher
In general I'm not a fan of not allowing cars to go to the exterior of a corner to gather speed since it makes the lap longer. The track limits nonsense is just like VAR in football, needlessly complicating things that don't need to be.
The rule should basically be "don't take the p-" like the 2019 Austin IndyCar race where they went five metres wide every lap in the penultimate corner. Those places should just get gravel traps to disincentivize that. Bahrain T4 though... that is a garbage rule for that and Parabolica. The advantage of running wide in those corners are so minor it doesn't really do anything. If it's that big of an issue, just put gravel there.
I couldn't watch Norris' video because it's way too long and I couldn't luck my way into skipping to the point where he talks about this, but I did watch the highlights and I see what he means. We must still consider though that while Max completed the overtake before running wide, the same line and speed he took through the corner that allowed him to make the pass also made him go wide. So if he had reined his car in to avoid going off he might not have been able to make the pass.
In Lewis's case, exceeding track limits 29 times does have 2 advantages.
1) tyre preservation
2) time advantage....Lewis gained 5 to 6 seconds total.
Had track limits been enforced during the race, it's possible Max would have had an opportunity of overtaking Lewis BEFORE T4....quite possibly on the straight. Max had the faster car at Bahrain.
Tyre wear - going from an abrasive track to a non-abrasive part of the track by exceeding track limits.
Time gained - taking a longer racing line by exceeding track limits at a greater speed....not much...but greater than keeping 2 wheels within the lines.
Max - did'nt exceed track limits 29 times or 21 times. Nothing has said as to the amount of times Max exceeded track limits.
So what's the evidence other than just you saying it? Max ran wide also you don't know how many times so how much tyre wear did he save and time?
Why is outside of the white lines not abrasive? do they use different tarmac? Would coming back on over the kerbs not cause tyre wear? How have you worked out 5 to 6 seconds time gained, what is this based on?
Have you just made this up?
Did'nt Max overtake Lewis on exceeding track limits thereby carrying greater speed?? Yes, the tarmac is different outside the white lines. It's not as abrasive. Most drivers go over one side of their car over the kerbs at various tracks and there has been no inconsistencies with one side of the car having more wear than the other....OTHER than more left handed corners than right handed corners.
It's been estimated at T4, exceeding track limits gave the driver 2/10's time advantage each time. So 2/10's multiplied by 29 times is 5.8sec.
