Are all Renault powered teams using the same Electronic Recovery Systems? Is it all part of the same powerplant package?
Printable View
f1today: Force India had a problem with the fuel supply earlier today, that is why Nico Hulkenberg stopped on track. And the late start was caused by a problem with the gearbox.
Renault has their problems, but yes, it's also RedBull's packaging that's making it hard work. BUT it's solvable, and probably will be solved soon enough. That's the point i wanted to get across, seeing that some are writing them off already even though their car looks really well designed and a perspective front runner.
Edit : never mind
Merc will be very very strog
they say that the Marussia is out on track, photos anyone???
This year the Ferrari RED colour is wonderful in the direct sunshine.
Nice to see Ferrari continue doing aero work
Yh they don't look new, just a different angle than we have seen! did get me thinking tho
Ian Parkes @ianparkesf1
Red Bull are done for the day as Christian Horner and Adrian Newey have just been driven out of the circuit
newey and allison already questioning the legality of the mclaren suspension. it is a moving aero device!!!
@paolofilise
#F1Jerez Red Bull problem is a packaging problem. Battery and ERS elements are too close to heat sources and suffer quick overheating
Not that it is a moving aero device...but this...
McLaren's rear-suspension looks to have aroused yet another team's interest, with Red Bull's Adrian Newey questioning its legality. The Woking squad, which struggled throughout 2013 and are looking to bounce back this year, debuted an innovative suspension solution at the rear which mimics the now-banned beam-wing. Newey suspects it falls foul of the technical regulations though. "I have not seen the photos but as it is described, it sounds as though there are eight suspension elements, where only six are allowed," he said. "Moreover, there are clear rules for the width of the suspension." However, the FIA's Charlie Whiting is believed to have signed the design off as legal, and therefore a team must file a protest if they want action to be taken. If not, copying the idea could be very difficult for some of the teams, including Red Bull, Ferrari and Mercedes, according to technical analyst Gary Anderson. - See more at: http://www.f1times.co.uk/news/displa....VT5Pd0o8.dpuf
From Planet F1-
Full Article- http://www.planetf1.com/driver/18227...aises-eyebrows
Since re-designing the entire rear suspension layout is an arduous task, it comes as no surprise that Red Bull's technical wizard believes McLaren's solution is illegal.
"I have not seen the photos," he said, "but as it is described, it sounds as though there are eight suspension elements, where only six are allowed.
http://www.f1technical.net/development/435
The team's approach is far away from drag reduction. Instead, the elements are rather big with a cross section similar to a mushroom lying down on its side. Before we see how it works, it needs to be noted that the design has already been cleared as legal by the FIA. This means that the entire shape is structural, as otherwise the thick fairing would be considered as banned moving bodywork as per Article 10.3.4 of the Technical Regulations.
Article 10.3.1 further stipulate limitations to the cross section of the suspension arms, saying its longest dimension (main axis) may not be move than 100mm, and this axis can only be up to 5° off from being parallel to the reference plane. On top of that, the section must also be parallel among its main axis.
So, what McLaren have done is create a wishbone in the shape of a bell on its side. It's length is likely to be very close or exactly 100mm, while the height looks to be of similar dimension. This means the section has an aspect ration of close to 1:1, must less than the maximum allowed 3.5:1, therefore making the entire part legal.
