Results 1 to 3 of 3
Thread: Simulator
    Jun 2007
    Glenville, NY
    Simulator
    I want to build a cockpit of the f2008 to race rfactor in. I have done lots of research on this and feel it can be done. But I do need things I cant seem to find. I want to replicate the f2008 wheel but I do not know what each button does or where to find buttons and knobs like the ones found on the wheel.. or what each lcd screen is suppose to display. Also and inside cockpit shots or whats on either side of the driver would be great. And are the drives legs together or is there a piece separating them all the way down the nose to the pedals.
    Mar 2008
    F2008 STEERING WHEEL
    1. A row of lights that indicate the right revs for when the change gear.
    2. Multifunctional display that shows the gear the car is in. On the side of the central display the waved flags are displayed in colours (green, yellow, red, black etc.)
    3. Buttons that allows various information to appear on the display.
    4. Speed limiter.
    5. Button that permits different levels of revving.
    6. Radio.
    7. A new button that regulates response of the accelerator.
    8. A switch that takes care of the fuelmixture.
    9. Activates the auxiliary oil pump.
    10. Switching off the engine.
    11. A new button that regulates the power supply in function of the type of tyres mounted on the car.
    12. Confirmation of the radio, you never know...
    13-14-16. Switches that operate the differential going into a corner, being in the middle of one and coming out of one.
    15. Button that looks for the moment to activate the clutch.
    17. Engine boost allowing more revs for a short while.
    18. Neutral.
    Translation: AFCA
    I'm 90% sure that between driver's legs you won't find any separator.
    I don't have picture of cockpit sides but i have from Toyota. It's not the same car of course, but some things are the same or very similar.
    Šibenik, Croatia
    Quote Originally Posted by samster555
    Why don't you post them? I'm interested though I don't plan to build a cockpit...
