flex.jpgCould the wing section between vertical plates that connect the nose to the wing itself, be creating lift instead of downforce? If the right and left side of the wing can slightly "rotate/pivot" around its respective vertical plate, each endplate can move 5mm down if the absolute center of the wing moves 1mm up(rough estimate from simple geometry).
If the net downforce gained from the wing running closer to the ground is higher than that of the lift generated.....well theres more downforce.
Anyways...a stupid idea of mines...what do u guys think?
