Engine maps remain as 2012
Mapping setback for Renault
With the engine maps there have been troubles in the last year. The FIA subsequently lodged firmly a reference software. Under the engine manufacturers, there were different views on whether the mapping values also apply for 2013 as a base.
Do you remember Germany in the GP? Since the start of the Red Bull was Renault in the balance, because the FIA inspectors had discovered in the Renault V8 software that was suspicious. At full throttle, up to 35 percent torque were load controlled. In principle, this was nothing more than a kick-down kind of traction control. By retarded ignition were even then exhaust gases for aerodynamics produced if the driver was on gas. Not as much as in 2011, but still limited.
Red Bull as a loophole was discovered in the regulations. The restrictions for the ignition timing and the injection of gasoline applied to all states - not only to the full throttle position. Renault engineer Remi Taffin not understand to this day the excitement: "It was totally overrated We followed the rules and still do not understand why that should suddenly be illegal.."
New engine rules since August 2012
The governing body were of the opinion that Red Bull and Renault were also shot with this engine program on the target. Because it does not correspond to the spirit of the regulations. Therefore, on 24 August 2012 sent the technical directive No.19 to all teams, the creative mapping adjustments put a stop to.
From 6,000 rpm to full throttle, the firing angle must not exceed 2.5 percent, and the torque curve is not more than two per cent differ from a reference software. For this benchmark, the engine manufacturers were allowed to search for maps, which they had used for one of the first four races of the 2012 season.
Renault believed to reboot
It was not clear what scale should apply for 2013. Remains the same or may reference software the team early in the season to set a new foundation? Then Red Bull could theoretically retrieve the Hockenheim-field is possible. The statements on this were totally opposite.
Ferrari engine boss Luca Marmorini said: "Everything remains the same apply the 2012 regulations is therefore on the effect of the exhaust for the aerodynamics change anything..." Taffin colleague of Renault was of an entirely different opinion: "For us it's all over again we put in Melbourne set a new benchmark, the directive referred exclusively to the last year..."
FIA decides: 2012-rule remains valid
On request at the FIA states that it applies the Technical Directive No.19 of 2012. Renault has to start thinking so. Apparently the French were suspicious and made inquiries in the evening of the third day of testing even the FIA inspectors in Barcelona. The answer will not like it. It is expected that Renault has already tested new maps to optimize the exhaust effect on the aerodynamics. You can now pack up.
Mercedes team boss Ross Brawn understands that at Red Bull and Lotus pays no joy. "Their exhaust solution was probably designed so that one of the maps has more freedom. Exhaust solution of Red Bull and Lotus is in the towing of motor critical because as the exhaust blows less and less can contribute to the pressure, which means that you more dependent on the bottleneck. "
"The bottleneck, however, is at Red Bull and Lotus because of the ramp behind the tailpipes less pronounced. Therefore, this exhaust variant on corner entry it at a disadvantage compared to the solution as it has invented McLaren and all are followed up on Red Bull and Lotus. may well be that you wanted to compensate for the problem by a clever engine management system. "
