Thread: F14-T- Development & News
  1. #601
    Quote Originally Posted by Rishu View Post
    I would not mind Ferrari producing fundamentally the fastest car at the expense of reliability which can be ironed out later. 2010 Redbull was not reliable either but still won & later when all the reliability was ironed out, Red Bull dominated 3 years in a row.
    You need reliablity from the start. There are only 5 engines next year, rather than 8. A couple of blown engines early in the season will put you in a very difficult situation. If you end up taking a 6th engine, you will get a 10 place grid penalty in the first race you use it, and a 5 place grid penalty in every other race that you use it. Same for a 7th, 8th etc. engine. We need to be fast AND reliable, just like we were 10 years ago.
  2. #602
    Quote Originally Posted by Gerhard Berger View Post
    I was referring about the reliability caused by tight packaging & not engine but nonetheless your point is valid & engine reliability is even more important than ever.
  3. #603
    Aug 2003
    So in reality, it makes perfect sense to make an engine that will only last 1 race but with 200hp more. Should be relatively easy to make up the 10-place grid penalty.
  4. #604
    Quote Originally Posted by impactX View Post
    On paper everything is possible, in real life....
  5. #605
    C R O A T I A
    good idea but impossible. Engines will be frozen from 28th February onwards
  6. #606
    I dont know how our bodywork will be tight but I was speaking of our engine that is according to rumours sleeker, tighter and maybe lighter than other 2 engines...Regardless of the bodywork it is unknown if that tight engine will be reliable (everything is vague cos we dont have many facts but people were discussing for example exhaust pipe that goes straight out of the engine on ferrari and by renalult and mercedes there are extra pipes leading to exhaust pipe that come out from the side of the engine making it bulkier but allegedly preventing some overheating problems...)
    this is renault engine where u can see how bulky it is...
    And this is our engine, very sleek and not many pipes on the side :)
  7. #607
    Here's another small glimpse at the new teamwear:
  8. #608
    Why does it say race driver no 3?! Didn't FA picked No 14?
  9. #609
    This was uploaded on the 20th December 2013 and chosen numbers don't apply yet, since they aren't finalised.
  10. #610
    Thank you for the explanation. Didn't know that
  11. #611
    May 2013
    California, USA
    Although I think common consensus is that this would be seen as a phenomenal risk, this is actually a very interesting and out-of-the box idea... If an engine manufacturer could design an engine with excellent in-race reliability to last the full race distance, but with the plan to replace the engine after each race, then this would be down to how much trust a team places in driver ability, race strategy, assumption of overall risks, etc. as to whether they would ever contemplate such a thing. Maybe it would never happen, but interesting none-the-less.
  12. #612
    Dec 2008
    Barbados
    The problem with this approach is that the regulations are always subject to change which would wrong foot Ferrari immensely as the years go on with this engine formula.
    What I mean by this is the penalties for having to change your engine could be significantly increased each year as they have done in the past. So basing reliability, performance and penalty calculations on current regs is very dangerous when you have no control over the penalty regulations.
    There has been much talk about Ferrari potentially using exotic materials in their engine. Given the regulations limit the flexibility in this area with respect to exotic light weight materials for engine construction; if there is any truth to these rumours of exotic materials and given the layout of the exhausts I would assume that they have some sort of technical edge in the heat sinking properties of the exhaust outlets.
    Just compare the Renault design to the Ferrari sketch. Renault is clearly trying to both lower the centre of gravity and deal with the heat from the exhausts, while Ferrari has taken a more aero approach in keeping the lower areas around the engine block free for greater aero benefit. But there is a risk around the excessive heat over the engine. This had to be considered by the engineers and for this reason I believe they may have an edge around heat dissipation. The knock on effects in getting this right is tremendous.
    Better heat management, leads to tighter packaging, leading to greater flexibility around aero form factor which should provide greater levels of rear down-force which will be key with such "torquey" turbos.
    Looking forward to see how all of this develops.
  13. #613
    Hungary
    According to La Gazzetta dello Sport Jan-23. or 25. release the new Ferrari.
  14. #614
    Quote Originally Posted by f1tomi8 View Post
    As late as possible, before first test
  15. #615
    Oct 2011
    Toronto,Canada
  16. #616
    Macedonia(FYROM)
    Why, because now the front of the chassis is 10 cm lower then previous ,and pullrod at this situation will be more effectely
  17. #617
    Quote Originally Posted by gjoko-mkd View Post
    Well, only the nose tip needs to be lower though. The chassis can still remain high if the designer chose to do so. It may look weird, but if it provides better advantage, most team might do it.
  18. #618
    C R O A T I A
    Quote Originally Posted by Fer12 View Post
    they marked pull rod wrong
  19. #619
    May 2012
    croatia
    No no, the tube has to be lower to!
  20. #620
    Push rod is better than pull rod setup, right?
    Then they should reveal it in Jerez one day before testing begins like Mercedes did it last time...
  22. #622
    Macedonia(FYROM)
    Quote Originally Posted by radosav View Post
    Yes,this pictures shows that
  23. #623
    They can still make the step nose with vanity panel above it, like in 2013 right?
  24. #624
    There is no point in doing that. And even if they could, you can't have anything inside the vanity panel (suspension parts etc...).
  25. #625
    Edit: Nevermind. My bad I just realize that the max bulkhead height was 625mm in the past, while the new height will be 525mm. So the bulkhead should now be similar to McLaren's 2012 car, but the nose tip needs to be lower than McLaren's 2012 nose still, hence the elephant nose. That explains why the bulkhead is lower, but teams are still looking at ways to keeping it higher than what the FIA intended with sharply curving nose cone.
  26. #626
    Macedonia(FYROM)
    I think that every f1 car in the 2014 will be more or less similar with Mclaren Mp4-18
  27. #627
    That's a very good example, especially the front nose
    Here's what Caterham nose may look like based on their crash test video, very similar to that McLaren
  28. #628
    Quote Originally Posted by medeni73 View Post
    Off course! There is no need to rush with presentations as that was the case in 90's and early 2000, when there was unlimited testing.
  29. #629
    I don't mind this look at all!
  30. #630
    Quick question: how are the rules about "an extra engine"? Is it when you use your 6th engine, or can you simply say during the season this is our 6th engine, while you haven't used your 4th and 5th?
    It may sound stupid, but, if you can "choose the number of the engine", you can use the extra engine when you already have a penalty or bad qualy and when you're weekend is already spoiled...
    “The Ferrari is a dream - people dream of owning this special vehicle and for most people it will remain a dream apart from for those lucky few.” ~ Enzo Ferrari
