hope we have no teething problems with this new tyre rim and doesn't slow us down in the pits!
a full second behind the Merc and half as many laps run... but we have cool wheel nuts! yay! ugh...
My Pics from today in Bahrain
Maurizio Arrivabene fanpage:www.facebook.com/maurizioarrivabene
Whats with the separation here? Is it a change in CF thread layering? Or just clumsy work.
F1 show biz 2016 :
Toto - "Ferrari are a real threat" .... Nico - "Awesome, everything is just awesome" .....Lulu - "Mental strength man, lifestyle man, I'll drive at 400% as ever man".... and then suddenly a wild Bull out of nowhere slams into a Ferrari.
The wheel nut is not just a fancy looking wheel nut, it has air blowing through it for aero benefits, and the air is fed by the huge brake ducts hence the oversized brake duct we saw on the car.
Williams was the first team to try it last year, and here's an article explaining how it works (for Williams, but it's the same).
http://badgergp.com/2013/02/blown-wh...et-innovative/
Given our engine problem, any technique to reduce drag will come in handyAfter some technical meetings by the FIA at the 2012 Canadian Grand Prix, it was announced that Red Bull would have to seal some holes on the front wheel rims of the RB8. These holes were actually producing an aerodynamic effect by feeding airflow through the front brake ducts, through the front axle and to the outside of the front wheels through these holes in the wheel rim. The reason for this is to try and reduce drag created by the front wheels by redirecting airflow into the wake of the front wheels, away from the tyre itself which is a high source of drag, and produce a “cleaner” airflow going rearwards to the rest of the car. However, because the holes were incorporated into the wheel rim they rotated with it, which is possibly why it was declared a “moveable aerodynamic device” - something which is against the regulations.
Back to Williams and their new wheel nut design, this is essentially performing the same function as what Red Bull were trying up to the Canadian GP. Airflow is redirected via the front brake duct, through to a hollow duct that allows airflow to escape via the open-ended wheel nut to the outer edge of the front wheels. The difference here though is because the effect is produced via the wheel nut this does not rotate or move, therefore making this legal. The only downside to this is the front brake ducts have to be larger to make this work, which will produce more drag, so it is a bit of a balancing act.
Set-up testing for Alonso
Circuit: Sakhir circuit– 5.412 km
Driver: Fernando Alonso
Car: Ferrari F14 T
Weather: air temperature 25/32°C, track temperature 31/44 °C. Sunny.
Laps/Km completed: 69/373
Best time: 1:36.626
Fernando Alonso was back behind the wheel of the F14 T at the Sakhir circuit today at the start of the first of four in-season tests, reintroduced this year after a two year break.
In the morning, the team concentrated on fine tuning various electronic configurations and on taking aerodynamic measurements with constant speed runs down the main straight. In the afternoon, work was carried out in short runs, lapping to evaluate different set-up choices.
Alonso will again be on track tomorrow, as Scuderia Ferrari tackles the second and final day of this test.
- See more at: http://formula1.ferrari.com/news/set....Xdus1ba7.dpuf
Can it be a narrow slightly shallower pathway leading to the rear? Also dont compare with the sidepod, but to other floor areas.BY da way i meant the black line not the reflection on the floor.
F1 show biz 2016 :
Well u can put holes on the wheel nuts too,then instead of making them open ended. Clearly the tighter the volume, more energised the flow and if the outward airflow is aiding the rear, that energy ill help in mitigating flow separation.
F1 show biz 2016 :
F1 show biz 2016 :
Bahrain Test, Day 1 – Tuesday, 8 April 2014
Driver Team Time Laps
1. N. Rosberg Mercedes Grand Prix 01:35.697 (121)
2. N. Hulkenberg Force India F1 01:36.064 (68)
3. F. Alonso Ferrari 01:36.626 (67)
4. K. Magnussen McLaren 01:36.634 (101)
5. V. Bottas Williams 01:37.305 (28)
6. M. Chilton Marussia 01:37.678 (60)
7. D. Ricciardo Red Bull 01:38.326 (91)
8. S. Sirotkin Sauber 01:39.023 (75)
9. R. Frijns Caterham 01:40.027 (63)
10. P. Maldonado Lotus Renault 01:40.183 (16)
11. D. Kvyat Scuderia Toro Rosso 01:40.452 (67)
I was hoping for a vastly different looking Ferrari. I do hope the tests puts us on a much better footing for the next race.
If todays lap times are compairable we already made some progress. This is bahrain, not a good track for us.
Definitely a worry. All the top teams did close to or more than 100 laps. Mercedes are working like a machine! I'm guessing that Ferrari were experimenting with new PU settings. Unfortunately, this kind of approach can lead to failures and lost time. This problem seems to be compounding itself. We have yet to hear from the team itself that we have made progress with our PU. I'm afraid it just looks like we're falling further and further behind.
marussia was running on FUMES and maybe Alonso did not push too hard as they were running a lot of aero corellation....
common, do u rellay think masussia is ONLY 1 second slower then us....
we'll get there boys, soon...somehow i have a feeling that by SPAIN Ferrrari will be ON PAR with Mercedes....if not FASTER!!!! have faith you guys!!!
Strange that Williams only did 28 laps & that is all they wanted to do? Also did probably the least (thought I heard) during FP1, 2, 3. Sure are confident of their car, or worried about PU longevity (that doesn't seem likely, tho').
Unless Ferrari are allowed to modify the engines and somehow find a HUGE amount of power, they'll always been 0.5 to 1.0 seconds behind Mercedes. They've been consistently 7-10 kph slower in the trap speed.
F1 show biz 2016 :
BTW.. Hulk used Supersofts..
Check the other pics here on my FB Album
https://www.facebook.com/RaztaF1/med...1831.504098873
