Results 1 to 5 of 5
Thread: Ferrari Portofino 2018
    Love the way this car looks. Nice lines all the way around. Classic Ferrari.
    http://auto.ferrari.com/en_US/sports...ari-portofino/
    and video
    https://www.youtube.com/watch?v=V3cNrKP0Z_8
    THE FERRARI PORTOFINO REVEALED
    A GT THAT REPRESENTS A UNIQUE COMBINATION OF SPORTINESS, ELEGANCE AND ON BOARD COMFORT
    Maranello, 23 August 2017 – The Ferrari Portofino is the new V8 GT set to dominate its segment thanks to a perfect combination of sportiness, elegance and on board comfort.
    Ferrari has chosen a particularly evocative moniker for this exceptionally versatile drop-top car, referencing one of Italy’s most beautiful towns. Portofino is renowned for its charming tourist port and, over the years, has become internationally synonymous with elegance, sportiness and understated luxury. The launch colour of the new Ferrari has also been dedicated to this marvellous town: Rosso Portofino.
    LIGHTER CHASSIS, MORE POWERFUL ENGINE
    Capable of unleashing a massive 600 cv and sprinting from 0 to 100 km/h in just 3.5 seconds, the Ferrari Portofino is the most powerful convertible to combine the advantages of a retractable hard top, a roomy boot and generous cockpit space plus two rear seats suitable for short trips.
    The Ferrari Portofino’s all-new chassis features a significant weight saving over the California T it replaces. Thanks to the extensive use of modern production technologies, all the chassis and body-in-white components have been redesigned with a consequent reduction in weight despite an increase in torsional rigidity.
    ENGINE
    The renowned Ferrari V8 turbo, part of the engine family that was nominated International Engine of the Year in both 2016 and 2017, now punches out 40 cv more than the California T’s power unit thanks to the adoption of new components and specific calibration of the engine management software. The characteristic Ferrari V8 soundtrack has also been further enhanced and can be fully appreciated, particularly in top-down driving.
    All aspects of the 8-cylinder’s efficiency have been honed with the adoption of new pistons and con-rods, and a new intake system design. The geometries throughout the exhaust system have also been revolutionised. The new one-piece-cast exhaust header reduces losses, an important factor in ensuring Ferrari’s characteristic throttle response with zero turbo lag. These improvements, combined with the Variable Boost Management which adjusts torque delivery to suit the gear selected, enable the Ferrari Portofino to offer even higher levels of acceleration in all gears and lower fuel consumption compared to the outgoing model.
    VEHICLE DYNAMICS
    The Ferrari Portofino’s vehicle dynamic characteristics have been completely revised and benefit from the introduction of new technological solutions. For the first time on this type of Ferrari model, the third generation electronic rear differential (E-Diff3) has been adopted and integrated with the F1-Trac, improving both mechanical grip and the control of the car on the limit. The Ferrari Portofino is also the first GT in the range to be fitted with EPS (Electric Power Steering). This allowed the engineers to reduce the steering ratio by seven per cent for even more responsive steering without a trade-off in stability thanks to the integration with the E-Diff3. The magnetorheological damping system (SCM-E) has been uprated with dual-coil technology which helps reduce roll while simultaneously improving absorption of road surface unevenness. The result is an even more dynamic, responsive car that also delivers superior ride comfort.
    DESIGN AND AERODYNAMICS
    The Ferrari Design Centre-penned Ferrari Portofino is an aggressively-styled car with a two-box fastback configuration – unprecedented in a coupé-convertible with a retractable hard top – that adds extra sleekness to its silhouette, lending it a sportier character without impinging on its elegance and dynamism.
    Close collaboration between the Aerodynamics department and Ferrari Design has ensured maximum efficiency in the development of the surface treatment. Starting with the front, the form of the large radiator grille opening, that stretches from edge to edge of the carefully contoured nose, is underscored by a new full-LED headlight assembly with a more horizontal shape. The outside edge of the headlight hides an innovative air intake which vents into the front wheelarch and exits along the flank to reduce drag.
    The tail design underlines the car’s sporty stance which has been further enhanced by placing the tail lights futher apart. This elegant solution cleverly conceals the rear volume housing the all-new RHT which features a more lightweight design and can be raised or lowered at low speeds.
    COMFORT ON BOARD
    There was also a particular focus on board comfort which is guaranteed by a slew of new features, not least an infotainment system with 10.2” touchscreen display, a new air-conditioning system that improves occupant comfort both with the top up or down, a new steering wheel, 18-way electrically adjustable seats with a new backrest design that boosts legroom for rear seat passengers, and the passenger display. All occupants will particularly appreciate the new wind deflector which, when the top is dropped, cuts air flow inside the cabin by 30% and also reduces aerodynamic noise.
    The Ferrari Portofino will make its world debut at the Frankfurt International Motor Show in September.
    TECHNICAL SPECIFICATION
    ENGINE
    Type V8 – 90°
    Overall displacement 3855 cm3
    Maximum power output * 441 kW (600 cv) at 7500 rpm
    Maximum torque * 760 Nm from 3000 to 5250 rpm
    WEIGHT AND DIMENSIONS
    Length 4586 mm
    Width 1938 mm
    Height 1318 mm
    Weight distribution 46-54% front/rear
    PERFORMANCE
    Maximum speed >320 Km/h
    0-100 km/h 3.5 sec
    FUEL CONSUMPTION AND CO2 EMISSIONS**
    Fuel consumption 10,5 l/100km
    Emissions 245g CO2/km
    NOTE
    * In 7th gear
    ** Combined cycle. Under homologation. ECE+EUDC with standard HELE system.
    The Portofino is grand improvement over the California (meh)/California T(much better) and the only convertible/hardtop with unclumsily decent cut lines in the roof transition area while the performance (on paper) seems yet another step forward.Of course they're all paler in looks to the divine lines of 1957 250GT California Spyder, and the song of it's V12 is unadulterated and unmassaged classical music!
    I tried to find any road car relevance(past history) to the Portofino and came up with nothing other than it bears the name of an Italian city along the Italian Riviera....what
    better way to drive through it with the top down and coin the name of the town.
    An improvement over its predecessor, but that wasn't exactly difficult. It still looks like a mini-F12 however and has yet to forge a unique identity except as the cheapest Ferrari (not that I can afford it anyway).
    Portofino is a beautiful jewel and it has hopefully remained unadulterated. I know of no relevance of it to Ferrari, motorcars or racing but it has always been home to the wealthy and a jet-set destination and maybe Ferrari would like
    to cultivate and compliment it's well-heeled habitues for future patronage;) Actually you can only reach it by boat or trail so you could not drive your Portofino there though you could wear your IWC watch there?
