Pardon my gimp skills, this is what I'm maybe tricking my self into seeing.
I'm sort of seeing an undercut there.
I sub to Kyleengineer as well and I really enjoy his analysis and respect his insight since he was an actual aerodynamicist for Mercedes F1.
Like most things, there is always a compromise to a design. We know that air going into the chassis needs to have a way of getting out to be most efficient. We also know the minimum amount of air going through the car is ideal. If the aero guys could close up all the ducts 100%, they would be happy campers, but that's not feasible. In the case of AM, they have an extreme undercut which allows the air to flow under the sidepod all the way to the diffuser, which helps the efficiency of the diffuser. The louvers are a good way to get rid of the hot air, though even Kyle mentions how it is dirty air that will disrupt the flow towards perhaps the beam wing or the rear wing. If AM could not have louvers with the same sidepods, I am sure they would. But it's a good cooling solution for their sidepod design. Ferrari on the other hand have very little undercut, judging from that picture. It appears to be a relatively flat surface around the Ceva and Shell logos, and the distance from the lower sidepod to the edge of the floor is only a few inches. A much smaller undercut than AM, or any other team. I can't see how the air will flow towards the diffuser like it does on the AM with such a small undercut. In general sidepod volume, the Ferrari's does not appear to be nearly as tight as the AlphaTauri for example, so in my eyes the Ferrari sidepods are the largest. There are cooling openings at the rear A arm connection point (the A of Santander) as well as a small opening around the exhaust. Yet they still are using a full set of louvers as well. This doesn't suggest the cleanest airflow to the rear of the car.
Of course this all based off 1 simple picture and it is virtually impossible to know for sure without seeing more.
Looking closer, it appears maybe the sidepod is shaped similar to that of the F399 or the McLaren MP4-26. This could keep the airflow on the top of the sidepods in between the rear tires. The angle right off the sidepod inlet is being used to kick the wake outwards and away from the rear tires, so I can't figure a good way or good reason to want airflow attached to the flat surface of the sidepod (Ceva & Shell logos).
I didn't bother looking at the nose of the car, can't comment much on something that is mostly hidden.
Appreciate the insight, I missed the extra cooling exit near the Santander logo. It does seem like the AM louvers are running further down then the Ferrari. I still will be clinging to hope about there being an under cut.
Also this quite from Jean Alesi makes me hopeful:
"I saw the Ferrari earlier. It is a real marvel, very, very slim, with a bit of a sophisticated nose.
The car is already impressive, and I hope it will go as fast to join the two [best] teams we had last year with Mercedes and Red Bull."
I mean he saw more for the car than a single picture at an angle, so maybe it really is tighter than it looks there.
I've taken some aerodynamic classes in college.
With regards to cooling louvers on top of the sidepod in F1, they are not aerodynamically efficient to dissipate heat.
I've seen cooling louvers next to the drivers cockpit as being more aerodynamically efficient. Also, the rear openings of the engine cover before the rear axle as well is more aerodynamically efficient.
The conundrum is you want the sidepods as smooth (aerodynamically) as possible. Putting louvers on top of the sidepods increases heat dissipation but also increases drag.
Maybe for a track like Monaco or Singapore one might use the louvers on top of the sidepods where speed is not an issue. However, for tracks like Spa, Monza and Baku speed is a factor and you want the minimum drag as possible.
I've also noticed that some cars have a higher nose to ground clearance while other have a closer nose to ground clearance.
IMO, the closer nose to ground is more aerodynamically efficient.
Maybe ferrari did this on purpose and had it leaked to throw everyone off for tomorrow.jean alesi said he saw the car in private and said very unique nose and very very slim car and people will be in shock when they see it tomorrow
Só apparently today there was a private presentation for some VIP Guests. The leaked picture IS THE REAL DEAL... But it seems that however shared just shared the least revealing of it, otherwise see the comments of Jean Alesi abbot the nose...
https://f1i.com/news/432092-alleged-...oes-viral.html
Can't wait to see it tomorrow ������
So apparently today there was a private presentation for some VIP Guests. The leaked picture IS THE REAL DEAL... But it seems that whoever shared just shared the least revealing picture of it, otherwise see the comments of Jean Alesi abbout the nose...
Ferrari design develope all the rest just produce poor copies no matter what car from f1 to super cars to rd cars including suv range,and those deranged morons from other car makers always think they have produced something special good luck with that thought numbskull.
It's always very interesting to see how teams manage their cooling solutions, especially mid to late 2000s.
2003 Ferrari comes out with the shark gils
2004 Ferrari retains the shark gils to begin the season, but move to chimneys because they blew the hot air to the outside of the car, which was more efficient.
2005 Ferrari used fins that guided air to the side winglets, but when needed had chimney's and gils. The car had some cooling efficiency issues.
Renault had chimneys and used full body louvers.
2007 Ferrari and Renault are using full body louvers, but McLaren are using the chimneys still.
It's such a compromise. Upper body airflow vs lower body airflow, drag vs downforce, cooling vs aero.
I think it's going to be hard to judge these cars right now. At first glance the Ferrari doesn't seem as detailed or as finished as the AT or the Wiliams even. But, Binotto does say that most of the gains are to be found under the car in the new ground effects diffusers. I take this to mean that the coke bottle maybe isn't as critical as it was before because the diffuser outlets are so much taller that perhaps working the air from the top of the pods down to the diffuser works better. Plus it opens a better path to the rear wing.
Is it legal to have open air space along the nose to funnel air to the top of the sidepods? It almost looks like that's what Ferrari is doing with the long narrow cooling openings on the front of the side pods. Might be the picture, but it seems the cooling openings are away from the nose and there is a channel for air to flow through onto the scalloped part of the sidepod.
It would be clever to use the sidepod cooling openings to enclose the side impact bars but leave the part closest to the nose open so air is allowed to enter the top of the pods and the cooling opening is moved to the outside towards the bulkier part. so there is a channel for air to run along the nose and onto the dip in the sidepods unencumbered.
Ferrari launch F1-75 | F1 2022 Car Launch
https://www.youtube.com/watch?v=5nvDe5VPHXI
I bet if it was the Red Bull, he would've been fangirling all over it.
According to Mr. Expert Aerodynamicist, our boxier sidepod is "horrendously" big. Which is a false statement ofcourse. It seems Mr. Expert Aerodynamicist only looking at it in top view....
The sidepods bottom side remain very close to the floor edge. Also it's nothing like the AM. The AM has big undercut and coke bottle area. Ferrari on the other hand is completely opposite.
Just for fun, while we wait for the real launch.
https://www.youtube.com/watch?v=I0Z4OfX0PvE
Hope our car is as strong as a tank as in the video..:d
Always trying to start a fight hey man?
I guess I must be Mr Expert Aerodynamcist since you literally said everything I did and pretend you thought of it yourself. That alone is laughable, but then you go to agree with the fact the Ferrari's sidepod extends nearly to the floor edge and that AM has the bigger undercut, and then you say the my observation that Ferrari's sidepods look huge is "false".
Relax guys, season hasn't started yet. Plenty of time to kill each other... Nobody knows for sure if this is "the car", some previous version of it, a mock up or photoshopped image. Design is always a compromise so some aspects of the design may seem less than ideal when viewed in isolation, but without knowing the overall design concept, its irrelevant. Bodywork comes and goes throughout the season. As long as the motor kicks butts, and the basic car is a rocketship, it's all good.
Let everyone see the side of the car, because with any luck all they'll see for the rest of the season is the rear end.
Just calling out your usual BS.
Hey, I'm not the one who dubbed our car as "worst design" already. Since you can give judgement on whether a car has great or bad design just by looking at a single picture, so it's a pretty big question why an expert like yourself haven't been employed by a F1 team yet.
I bet when you saw the Red Bull, you deemed it to be the greatest design eva, even if it was just the slow car with Red Bull's average looking livery.
